[petsc-dev] Attaching DMKSP/SNES/TS with PetscObjectCompose()	change
    Matthew Knepley
    knepley at gmail.com
    Fri Nov 30 11:30:51 CST 2012
On Nov 30, 2012 11:17 AM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>    I would like to add to the _p_DM  struct
> PetscObject  dmksp, dmsnes, dmts.
>    The current model that uses PetscObjectCompose() is a mis-use of
PetscObjectCompose(), why?
> The PetscObjectQuery() is always used for every function evaluation in
every time step, every Newton step, …
> 1) this is a performance problem with small size ODEs for example
> 2) PetscObjectQuery is suppose to be for exceptional things that occur
seldomly, not ones that occur inside the main computational routes.
>    Please send any technical (not philosophical) reasons why making this
change is a bad idea and will haunt us later.
There is an extensibility problem that Jed has already noted.
  Matt
>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121130/64f5c7f4/attachment.html>
