[petsc-dev] migrating repos from petsc.cs.iit.edu to bitbucket.org
    Satish Balay
    balay at mcs.anl.gov
    Fri Nov 16 14:10:11 CST 2012
On Fri, 16 Nov 2012, Barry Smith wrote:
> On Nov 16, 2012, at 11:14 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > I'm in the process of migrating repos from petsc.cs.iit.edu to
> > bitbucket.org, and have to resolve a few organization issues.
> > Restrictions.
> > - all repos should be lowercase
> > - no subdir organization possible [like http://petsc.cs.iit.edu/petsc/externalpackages/]
> > 1. Since we are forced to change reponame from 'BuildSystem' to
> > 'buildsystem' - I'd like to take this opportunity to change it to
> > 'buildsystem-dev' to be consistent with petsc-dev. i.e instructions
> > will be:
> > hg clone https://bitbucket.org/petsc/petsc-dev
> > hg clone https://bitbucket.org/petsc/buildsystem-dev petsc-dev/config/BuildSystem
> > or
> > hg clone https://bitbucket.org/petsc/petsc-release
> > hg clone https://bitbucket.org/petsc/buildsystem-release petsc-release/config/BuildSystem
> > and current clones would need updates to .hg/hgrc only.
> > one alternative was to change the path in source to
> > petsc-dev/config/buildsystem but it will cause some breakage and other
> > inconsistencies in source file naming scheming - so I'm against that
>    What breakage. I really don't like having caps in one place and small letters in another. Horrible inconsistency
I guess one can anticipate all issues and make configure deal with
them. [with autofix - or with an error message]. The couple of
issues I was thinking off:
- different organization between petsc-release and buildsystem confusing
users.
- configure might automatically create a new 'buildsystem' clone - when
the user might still have BuildSystem - and attempt to make changes there.
- bisection might need manual tweaking if if needs to go back and
  forth over this changepoint [from BuildSystem to buildsystem]
Also we won't have consistant naming of 'reop' to 'file' anyway. So I
see not much motivation to preserve the 'lowercase' part of the
attribute.
i.e buildsystem-dev -> buildsystem
    buildsystem-release -> buildsystem
Also with this rename - lot of sourcefiles/dirs have to be renamed
[for a consistant lowercase naming scheme] - loosing annotations in
mercurial history [perhaps mercurial should handle this automatically
- but I haven't checked it in depth].
Satish
>     Barry
> > another alternative is to use 'petsc', 'buildsystem', 'petsc-release',
> > 'buildsystem-release' [but we have too much baggage referring to
> > petsc-dev, with a mailing list etc reusing this name]
> > 2. I plan to reorganize external package repos [that we might have
> > patches for] with a pkg prefix.
> > i.e
> > http://petsc.cs.iit.edu/petsc/externalpackages/metis-5.0.2
> > http://petsc.cs.iit.edu/petsc/externalpackages/parmetis-4.0.2
> > to:
> > https://bitbucket.org/petsc/pkg-metis-5.0.2
> > https://bitbucket.org/petsc/pkg-parmetis-4.0.2
> > etc..
> > 3. Are AMS, ctetgen, win32fe special packages and be listed at toplevel?
> > currently ctetgen is listed under 'externalpackages'. Should it be at toplevel?
> > i.e
> > https://bitbucket.org/petsc/win32fe-dev
> > https://bitbucket.org/petsc/ams-dev
> > https://bitbucket.org/petsc/ctetgen-dev
> > Any thoughts?
> > thanks,
> > Satish
