[petsc-dev] Notification: Fwd: You have hereby been granted admin access to jedbrown/petsc-dev.
Fri Nov 16 14:01:17 CST 2012
On Fri, Nov 16, 2012 at 2:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   In petsc-XXX/config/   what will you call BuildSystem?  BuildSystem,
> buildsystem, buildsystem-dev, buildsystem-XXX
>    It would be nice to have totally consistent naming of the same thing in
> different places but do we really want petsc-XXX/config/buildsystem-yyy
> where
> yyy is different depending on release or dev?
If we used hg subrepo, each PETSc version would reference a SHA1 from
buildsystem. Then we could just have buildsystem. When a patch needed to go
into "buildsystem-release", we would apply the patch to the buildsystem
version that release depends on and update petsc-release to reference that
SHA1, independent of the existence of post-release patches (only relevant
to petsc-dev) in the buildsystem repository.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121116/ad49c4e0/attachment.html>
