[petsc-dev] migrating repos from petsc.cs.iit.edu to bitbucket.org
Fri Nov 16 11:14:17 CST 2012
I'm in the process of migrating repos from petsc.cs.iit.edu to
bitbucket.org, and have to resolve a few organization issues.
Restrictions.
- all repos should be lowercase
- no subdir organization possible [like http://petsc.cs.iit.edu/petsc/externalpackages/]
1. Since we are forced to change reponame from 'BuildSystem' to
'buildsystem' - I'd like to take this opportunity to change it to
'buildsystem-dev' to be consistent with petsc-dev. i.e instructions
will be:
hg clone https://bitbucket.org/petsc/petsc-dev
hg clone https://bitbucket.org/petsc/buildsystem-dev petsc-dev/config/BuildSystem
or
hg clone https://bitbucket.org/petsc/petsc-release
hg clone https://bitbucket.org/petsc/buildsystem-release petsc-release/config/BuildSystem
and current clones would need updates to .hg/hgrc only.
one alternative was to change the path in source to
petsc-dev/config/buildsystem but it will cause some breakage and other
inconsistencies in source file naming scheming - so I'm against that
another alternative is to use 'petsc', 'buildsystem', 'petsc-release',
'buildsystem-release' [but we have too much baggage referring to
petsc-dev, with a mailing list etc reusing this name]
2. I plan to reorganize external package repos [that we might have
patches for] with a pkg prefix.
i.e
http://petsc.cs.iit.edu/petsc/externalpackages/metis-5.0.2
http://petsc.cs.iit.edu/petsc/externalpackages/parmetis-4.0.2
to:
https://bitbucket.org/petsc/pkg-metis-5.0.2
https://bitbucket.org/petsc/pkg-parmetis-4.0.2
etc..
3. Are AMS, ctetgen, win32fe special packages and be listed at toplevel?
currently ctetgen is listed under 'externalpackages'. Should it be at toplevel?
i.e
https://bitbucket.org/petsc/win32fe-dev
https://bitbucket.org/petsc/ams-dev
https://bitbucket.org/petsc/ctetgen-dev
Any thoughts?
thanks,
Satish
