[petsc-dev] PetscSection
Thu Nov 8 23:19:16 CST 2012
On Thu, Nov 8, 2012 at 10:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I don't care about expensive VecGetArray(). We do it absolutely
> everywhere in PETSc.
> We recommend that users do it. This is not a real objection.
We normally do one VecGetArray(), then iterate over the whole local part.
That's different from doing it in an inner loop. Many other packages do it
in inner loops (overloading operator[] is popular among some), but that
restricts the Vec types that can perform well with that package.
> > What other sections do users need? A trace space?
> Blaise uses a couple for every problem. We have several in PyLith
> (ground surface,
> fault).
What is the difference between using a PetscSection for each thing and
using an IS for those points on the feature? I guess just the extra
indirection (IS) versus more duplication (a PetscSection is heavier than an
IS).
> > How do you intend to support many threads calling
> DMComplexVecGetClosure(),
> > perhaps each with multiple buffers, without expensive instructions?
> GetClosure() is not a problem. All threads are reading from the same
> topology, and
> writing to separate output buffers. SetClosure() needs to be locked.
You need separate buffers per thread, but we can make DMGetWorkArray() have
a separate cache per thread. VecGetArray() is still not trivially cheap
because we need atomics. Maybe I'm being overly paranoid, but I don't like
the granularity that imposes.
> >> These are for multi-field splitting/
> > Clearly, but why do they need to be in PetscSection? We already need DMs
> > associated with fields.
Answering my own question: the distinction between DM and Section is that
the latter can address a discontinuous part of a Vec so addressing by field
does not imply a copy.
> Someone needs to know the splitting. If you had a DM, this info is
> still stuck down
> somewhere, so that DM is holding other DMs.
It's still not clear to me why they are needed. If PetscSection is
user-visible, can't they just be different Sections?
DMComplexGetFieldSection(dm,field,&fsection);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121108/6cf3c28d/attachment.html>
