[petsc-dev] PetscSection
Thu Nov 8 22:18:55 CST 2012
This is inevitable, but may still not resolve anything. I'm sure Matt will
correct whatever below is incorrect. The main question is whether to
promote PetscSection to a PetscObject or to hide/replace it with something
else.
So PetscSection is an unloved (by most) beastie that is sort of
intermediate between an IS and a DM. Its core functionality is to provide
indirect indexing with variable block sizes. It consists of two parts, the
first of which is less than a PetscLayout.
struct _n_PetscUniformSection {
  MPI_Comm comm;
  PetscInt pStart, pEnd; /* The chart: all points are contained in [pStart,
pEnd) */
  PetscInt numDof;       /* Describes layout of storage, point -->
(constant # of values, (p - pStart)*constant # of values) */
numDof is always 1 and PetscUniformSection is never referenced from a *.c
file so this is really just a range of valid "point" values [pStart...pEnd).
struct _n_PetscSection {
  struct _n_PetscUniformSection atlasLayout;  /* Layout for the atlas */
  PetscInt                     *atlasDof;     /* Describes layout of
storage, point --> # of values */
  PetscInt                     *atlasOff;     /* Describes layout of
storage, point --> offset into storage */
^^ These two fields are the essential part. Each index in [pStart,pEnd) is
mapped to a block of size atlasDof[p-pStart] located at atlasOff[p-pStart].
Matt composes these indirect maps for storing meshes and other indexing
tasks. This "unsorted offset mapping" is indeed used frequently in PETSc,
though outside of Matt's code, it's just raw arrays.
User's primarily encounter PetscSection when accessing unstructured meshes
or any time the number of degrees of freedom or locations of each "point"
(topological entity in the mesh) is not uniform. DMs do a similar thing
(provide more logical access to a Vec), but DMDAVecGetArray() is of course
only natural for a structured grid.
At the user interface level, provided the user doesn't need low-level
access to topology, I think there are three possibilities.
*1.* To compute a residual at a cell, user does
VecGetArray(F,&f); // normal access to the Vec
DMComplexGetHeightStratum(dm,0,&cstart,&cend); // "height 0" is like
codimension 0 with respect to the maximum topological dimension. Matt and I
have have a philosophical debate over whether users prefer to think in
"strata" (that can skip dimensions, so "height 1" could be a face, an edge,
or a vertex depending on what is stored in the mesh) or in "topological
dimensions" (where codim=1 is a "face" for a 3D mesh and an edge for a 2D
mesh).
DMGetDefaultSection(dm,&section);
for (c=cstart; c<cend; c++) {
  PetscInt off;
  PetscSectionGetOffset(section,c,&off);
  f[off+0] = residual of first equation at this cell;
  f[off+1] = residual of second equation;
  // brushing under the rug how we access neighbor values
The above is basically the current model. Matt has
DMComplexGet/SetClosure(), but that interface carries a sleeper reference
to the Vec's array and he says he plans to remove it.
*2.* Add DMComplex-specific access routines so the user does not need to
see the PetscSection. Presumably this would be something like
DMComplexGetPointOffset(dm,c,&offset); // offset into owned part of global
vector?
DMComplexGetPointOffsetLocal(dm,c,&loffset); // offset into local vector
*3.* Access cursors (another object).
DMComplexGetCursors(dm,Vec U,3,&uface,&ucellL,&ucellR);
// similar for F
DMComplexGetHeightStratum(dm,1,&fstart,&fend);
for (f=fstart; f<fend; f++) {
  const PetscInt *c;
  const PetscScalar *uL,*uR,*uF;
  DMComplexGetSupport(dm,f,&c); // left and right cells
  DMCursorGetValues(uface,f,&uF); // only used for staggered/mixed
discretization
  DMCursorGetValues(ucellL,c[0],&uL);
  DMCursorGetValues(ucellR,c[1],&uR);
  // Solve Riemann problem with "face" values uF[] (if using a staggered
discretization), uL[], and uR[].
  DMCursorRestoreValues(uface,f,&uF); // ...
The "advantage" of the cursors here is that DMComplex doesn't need to hold
the context manager itself (perhaps for multiple threads), the code dealing
with the number of concurrent accesses is outside the inner loop, and the
implementations of these accessors are trivial (offset). I think it's still
not compelling for the sketched discretization above, but consider also FEM
methods where we need to access all degrees of freedom on the closure of an
element. The following packs a buffer with the closure (because it's not
contiguous in memory).
  DMCursorGetClosure(cell,c[0],&uc);
*4.* Alternative suggestions?
I'm so sick of the name DMComplex. Let's just rename to DMPlex. It's
shorter and doesn't have a double-meaning. Or pretty much any other name
but "Complex".
For completeness, the last bit of _n_PetscSection:
  PetscInt                      maxDof;       /* Maximum dof on any point */
  PetscSection                  bc;           /* Describes constraints,
point --> # local dofs which are constrained */
  PetscInt                     *bcIndices;    /* Local indices for
constrained dofs */
These BC fields are for doing masked updates, such as VecSetValuesSection()
which ignores constrained dofs.
  PetscInt                      refcnt;       /* Vecs obtained with
VecDuplicate() and from MatGetVecs() reuse map of input object */
  PetscBool                     setup;
  PetscInt                      numFields;    /* The number of fields
making up the degrees of freedom */
  const char                  **fieldNames;   /* The field names */
  PetscInt                     *numFieldComponents; /* The number of
components in each field */
  PetscSection                 *field;        /* A section describing the
layout and constraints for each field */
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121108/51883384/attachment.html>
