[petsc-dev] cmake 2.8-10.1 failing on my mac
Wed Nov 7 22:32:00 CST 2012
I attempted --download-cmake=http://www.cmake.org/files/v2.8/cmake-2.8.10.1.tar.gz on linux and osx 10.6 and
that went through fine..
> Could not read file /Users/barrysmith/Src/petsc-dev/arch-test/CMakeCache.txt: IOError(2, 'No such file or directory')
I'm not sure what this means. Jed might have ideas.
Satish
On Wed, 7 Nov 2012, Barry Smith wrote:
>    I upgraded cmake on my mac and now configure hangs will running cmake. If I kill the cmake process I see the following in configure.log
>     When I use --download-cmake and it gets the old version then that runs fine. Has PETSc's cmake stuff been tested with 2.8-10.1?
>    Barry
>         Pushing language C
>         Popping language C
> sh: ['/usr/bin/cmake', '--version']
> Executing: ['/usr/bin/cmake', '--version']
> sh: cmake version 2.8.10.1
>             Pushing language C
>             Popping language C
> Invoking: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
> sh: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
> Executing: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
> sh: Running with trace output on.
> Running with debug output on.
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
> -- Configuring done
>                   CMake setup incomplete (status 9), falling back to legacy build
>       CMake configuration was unsuccessful
