[petsc-dev] remnants of pkg-config in BuildSystem?
Wed Nov 7 18:03:09 CST 2012
On Wed, Nov 7, 2012 at 5:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Isn't this totally ir-fucking-relevent since we use the mpicc compiler
> wrappers and that hides (by design) the includes and libs (and even the
> compilers :-))?
Sure, unless you hate wrappers. Perhaps you'd like to compile conftest
without linking MPI so that it can run on the login node.
> > and system stuff.
>    Yes, but what specific things that we use?
X11, OpenPA (which we should be using), cairo (which would be much better
for drawing than raw X), NetCDF, ImageMagick, Valgrind.
>    Oh, cool yaml has them, now if we could only generate real uses of yaml
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121107/025177d9/attachment.html>
