[petsc-dev] Extra String with new BuildSystem
Chekuri Choudary cchoudary at rnet-tech.com
Wed Nov 7 10:33:51 CST 2012
I have a custom vector type in a folder /src/vec/vec/impls/seq/seqgpu. With
the new BuildSystem, when I do a configure, I get an extra string
"VecSetValues_SeqGPU " in the automatically generated file
/src/vec/vec/impls/seq/seqgpu/ftn-auto/vecgpuf.c as shown below. This issue
did not occur  with previous BuildSystems. Please also find the header file
attached. I was wondering if I am doing something wrong or if something in
the BuildSystem has changed. Any help is greatly appreciated.
#if defined(__cplusplus)
extern "C" {
#endif
void PETSC_STDCALL VecSetValues_SeqGPU vecsetvalues_(Vec x,PetscInt *ni,
PetscInt ix[], PetscScalar y[],InsertMode *iora, int *__ierr ){
*__ierr = VecSetValues(
        (Vec)PetscToPointer((x) ),*ni,ix,y,*iora);
#endif
Thanks
Shiva
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121107/ee1d3193/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121107/ee1d3193/attachment.h>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121107/ee1d3193/attachment.obj>
