[petsc-dev] MatZeroRowsColumnsStencil does not have a	fortran	binding
    Blaise A Bourdin
    bourdin at lsu.edu
    Sun Nov  4 18:40:07 CST 2012
On Nov 4, 2012, at 1:28 PM, Jed Brown <jedbrown at mcs.anl.gov<mailto:jedbrown at mcs.anl.gov>>
 wrote:
Pushed to 3.3.
Thanks
In the future, can you make patches by committing locally and using "hg export" (or even "hg email")? This patch had DOS-style formatting that needed to be converted before applying.
Weird... the patch I sent shows up as unix (LF) line endings in bbedit. It looks like LSU's exchange server is doing something funky with line endings.
Blaise
http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/ca8b914ed071
On Sun, Nov 4, 2012 at 12:52 PM, Blaise A Bourdin <bourdin at lsu.edu<mailto:bourdin at lsu.edu>> wrote:
Right now, MatZeroRowsStencil has a fortran binding, but MatZeroRowsColumnsStencil does not.
Is it possible to add the binding for MatZeroRowsColumnsStencil in petsc-3.3 and petsc-dev?
I am attaching a patch for 3.3
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612<tel:%2B1%20%28225%29%20578%201612>, Fax  +1 (225) 578 4276<tel:%2B1%20%28225%29%20578%204276> http://www.math.lsu.edu/~bourdin
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121105/4aea2046/attachment.html>
