[petsc-dev] pkgconfig
Thu Nov 1 20:28:46 CDT 2012
On Thu, Nov 1, 2012 at 9:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 1, 2012, at 7:12 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Nov 1, 2012 at 7:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Matt,
> >    There are two things. (1) Generating one for a PETSc install that
> others can use and (2) using someone else's to build PETSc. to match the
> other package (say hypre already built)
> >    I don't see why (1) is a bad idea.
> > I think this is always a bad idea for the reasons I gave before, namely
> that due to the fragility it will
> > break frequently, and we will get all the breakage on petsc-maint.
> >    Certainly we will ALL WAYS test any other package we use with PETSc
> but can we not use the information in that packages pkgconfig to tell us
> what compiler to use etc.?
> > I am not really against this. However, how would this work?
>     We take their information and (try to) use it with a PETSc build, then
> we in our configure (as we do know) try to link in their library.
You mean this is a "controlling" package, where we take all the info and
use it in our configure, instead of
a package we are using. Sure that is just another way to input configure
options.
> > It says one compiler in pkgconfig, but we have
> > another from our config.
>      There won't be another one in our config since we are building with
> their information!
> > Are they the same? There is no simple way to tell. Are they compatible?
> Again, no
> > simple test. Thus, it would always have to be what the user typed in
> already, so what are we saving?
>    We are allowing people to (automatically when it works) build a version
> of PETSc that matches some package they already have installed. Yes this
> doesn't solve all the problems of the world but it is a nice feature.
Yes I am not agains this.
   Matt
>    Barry
> >    Matt
> >    Barry
> > On Nov 1, 2012, at 3:22 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > On Thu, Nov 1, 2012 at 3:56 PM, Jed Brown <jedbrown at mcs.anl.gov>
> wrote:
> > > Bah, the problem with pkgconfig is that it doesn't handle different
> versions in different places well. We should use it in most cases, however.
> > > I disagree. There is only one way to be certain of a configure
> setting, and that is to test it. This will only
> > > produce more mail from idiots who move their installation, or copy the
> config file, etc. There is no redeeming
> > > value in this idea.
> > >    Matt
> > > On Nov 1, 2012 2:41 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
> > > On Thu, Nov 1, 2012 at 2:59 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >   Does, should, PETSc generate appropriate pkgconfig information for
> itself?  Does, can, it use that information from other packages?
> > > pkgconfig is too fragile to be of any use.
> > >    Matt
> > >     Barry
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121101/c54a5ead/attachment.html>
