[petsc-dev] pkgconfig
Thu Nov 1 18:02:52 CDT 2012
We can still test the pkgconfig version, without trying all possible
variants. Also, pkgconfig says how to link static without overlinking,
which is a combinatorial problem otherwise.
On Nov 1, 2012 3:22 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Thu, Nov 1, 2012 at 3:56 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Bah, the problem with pkgconfig is that it doesn't handle different
>> versions in different places well. We should use it in most cases, however.
> I disagree. There is only one way to be certain of a configure setting,
> and that is to test it. This will only
> produce more mail from idiots who move their installation, or copy the
> config file, etc. There is no redeeming
> value in this idea.
>    Matt
>> On Nov 1, 2012 2:41 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
>>> On Thu, Nov 1, 2012 at 2:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   Does, should, PETSc generate appropriate pkgconfig information for
>>>> itself?  Does, can, it use that information from other packages?
>>> pkgconfig is too fragile to be of any use.
>>>    Matt
>>>>     Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121101/e4210270/attachment.html>
