[petsc-dev] Partial build
    Matthew Knepley
    knepley at gmail.com
    Wed May  2 19:48:28 CDT 2012
On Wed, May 2, 2012 at 5:02 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Normally both should work. Looks like 'lib' is broken.
The CUDA dependencies are broken for all builds.
   Matt
> Satish
> On Wed, 2 May 2012, John Fettig wrote:
> > To answer my own question, it looks like you have to use libfast, not
> lib.
> > John
> > On Wed, May 2, 2012 at 4:54 PM, John Fettig <john.fettig at gmail.com>
> wrote:
> > > If I modify src/vec/vec/impls/seq/seqcusp/veccusp.cu and then (in that
> > > directory) type "make lib", shouldn't it rebuild the library?  I have
> also
> > > tried "make ACTION=lib tree" from higher up, and it still doesn't
> rebuild.
> > >  What's the secret?  This works for .c files.
> > > Thanks,
> > > John
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120502/367999fb/attachment.html>
