[petsc-dev] redefine (or remove) MatPreallocateSymmetricInitialize to MatPreallocateInitialize
Lisandro Dalcin dalcinl at gmail.com
Sat Mar 31 07:45:01 CDT 2012
The patch at the end is perhaps a little hard to read, but the basic
idea is to redefine (or eventually remove)
MatPreallocateSymmetricInitialize, and use MatPreallocateInitialize.
For this, all what is required is to somehow trick the C compiler to
not complain about unused-but-set-variable (the -W warning name for
GCC). That is the "__start = 0; __end = __start;" change in the first
hunk.
If you agree, I'll like to push this change, and next I'll update the
code to use MatPreallocateInitialize() in all cases... What I'm not
sure is about removing MatPreallocateSymmetricInitialize, as it could
potentially break user code.
diff -r de0779566bd9 include/petscmat.h
--- a/include/petscmat.h	Fri Mar 30 16:54:32 2012 -0500
+++ b/include/petscmat.h	Sat Mar 31 15:27:23 2012 +0300
@@ -735,7 +735,7 @@
   PetscErrorCode _4_ierr; PetscInt __nrows = (nrows),__ctmp =
(ncols),__rstart,__start,__end; \
   _4_ierr = PetscMalloc2(__nrows,PetscInt,&dnz,__nrows,PetscInt,&onz);CHKERRQ(_4_ierr);
   _4_ierr = PetscMemzero(dnz,__nrows*sizeof(PetscInt));CHKERRQ(_4_ierr);\
-  _4_ierr = PetscMemzero(onz,__nrows*sizeof(PetscInt));CHKERRQ(_4_ierr);\
+  _4_ierr = PetscMemzero(onz,__nrows*sizeof(PetscInt));CHKERRQ(_4_ierr);
__start = 0; __end = __start; \
   _4_ierr = MPI_Scan(&__ctmp,&__end,1,MPIU_INT,MPI_SUM,comm);CHKERRQ(_4_ierr);
__start = __end - __ctmp;\
   _4_ierr = MPI_Scan(&__nrows,&__rstart,1,MPIU_INT,MPI_SUM,comm);CHKERRQ(_4_ierr);
__rstart = __rstart - __nrows;
@@ -772,14 +772,7 @@
 .seealso: MatPreallocateFinalize(), MatPreallocateSet(),
MatPreallocateSymmetricSet(), MatPreallocateSetLocal(),
           MatPreallocateInitialize(), MatPreallocateSymmetricSetLocal()
 M*/
-#define MatPreallocateSymmetricInitialize(comm,nrows,ncols,dnz,onz) 0; \
-  PetscErrorCode _4_ierr; PetscInt __nrows = (nrows),__ctmp =
(ncols),__rstart,__end; \
-  _4_ierr = PetscMalloc2(__nrows,PetscInt,&dnz,__nrows,PetscInt,&onz);CHKERRQ(_4_ierr);
-  _4_ierr = PetscMemzero(dnz,__nrows*sizeof(PetscInt));CHKERRQ(_4_ierr);\
-  _4_ierr = MPI_Scan(&__ctmp,&__end,1,MPIU_INT,MPI_SUM,comm);CHKERRQ(_4_ierr);\
-  _4_ierr = MPI_Scan(&__nrows,&__rstart,1,MPIU_INT,MPI_SUM,comm);CHKERRQ(_4_ierr);
+#define MatPreallocateSymmetricInitialize(comm,nrows,ncols,dnz,onz)
MatPreallocateInitialize(comm,nrows,ncols,dnz,onz)
 /*MC
    MatPreallocateSetLocal - Indicates the locations (rows and
columns) in the matrix where nonzeros will be
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
