[petsc-dev] DMCreateComposition crash in tests
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Fri Mar 30 21:21:32 CDT 2012
Barry,
This looks like petsc-dev from about a week ago -- I fixed this bug today.
It runs on my laptop right now.
Dmitry.
On Fri, Mar 30, 2012 at 9:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: ---------------------  Stack Frames
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [0]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > [0]PETSC ERROR:       is given.
> > [0]PETSC ERROR: [0] DMCreateDecomposition line 854
> /Users/barrysmith/Src/petsc-dev/src/dm/interface/dm.c
> > [0]PETSC ERROR: [0] PCSetUp_ASM line 161
> /Users/barrysmith/Src/petsc-dev/src/ksp/pc/impls/asm/asm.c
> > [0]PETSC ERROR: [0] PCSetUp line 810
> /Users/barrysmith/Src/petsc-dev/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: [0] KSPSetUp line 182
> /Users/barrysmith/Src/petsc-dev/src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: [0] KSPSolve line 339
> > [0]PETSC ERROR: [0] SNES_KSPSolve line 4169
> /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> > [0]PETSC ERROR: [0] SNESSolve_LS line 143
> /Users/barrysmith/Src/petsc-dev/src/snes/impls/ls/ls.c
> > [0]PETSC ERROR: [0] SNESSolve line 3345
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Signal received!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Development HG revision:
> ebfd90d136e614e3f7e877dc536ab77f25382894  HG Date: Fri Mar 23 21:43:17 2012
> -0500
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex50 on a arch-gnu named
> barry-smiths-macbook-pro.local by barrysmith Fri Mar 30 20:27:34 2012
> > [0]PETSC ERROR: Libraries linked from
> /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> > [0]PETSC ERROR: Configure run at Fri Mar 23 22:22:13 2012
> > [0]PETSC ERROR: Configure options --download-blacs --download-fftw
> --download-hypre --download-metis --download-mpich --download-mumps
> --download-parmetis --download-ptscotch --download-scalapack
> --download-superlu --download-superlu_dist --download-yaml
> --with-shared-libraries PETSC_ARCH=arch-gnu
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> > [cli_0]: aborting job:
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > [1]PETSC ERROR: Try option -start_in_debugger or
> > [1]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSCERROR: or try
> corruption errors
> > [1]PETSC ERROR: likely location of problem given in stack below
> > [1]PETSC ERROR: ---------------------  Stack Frames
> > [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [1]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > [1]PETSC ERROR:       is given.
> > [1]PETSC ERROR: [1] DMCreateDecomposition line 854
> > [1]PETSC ERROR: [1] PCSetUp_ASM line 161
> > [1]PETSC ERROR: [1] PCSetUp line 810
> > [1]PETSC ERROR: [1] KSPSetUp line 182
> > [1]PETSC ERROR: [1] KSPSolve line 339
> > [1]PETSC ERROR: [1] SNES_KSPSolve line 4169
> > [1]PETSC ERROR: [1] SNESSolve_LS line 143
> > [1]PETSC ERROR: [1] SNESSolve line 3345
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Signal received!
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: Petsc Development HG revision:
> -0500
> > [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [1]PETSC ERROR: See docs/index.html for manual pages.
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: ./ex50 on a arch-gnu named
> > [1]PETSC ERROR: Libraries linked from
> > [1]PETSC ERROR: Configure run at Fri Mar 23 22:22:13 2012
> > [1]PETSC ERROR: Configure options --download-blacs --download-fftw
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
> > [cli_1]: aborting job:
> > [2]PETSC ERROR:
> > [2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > [2]PETSC ERROR: Try option -start_in_debugger or
> > [2]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[2]PETSCERROR: or try
> corruption errors
> > [2]PETSC ERROR: likely location of problem given in stack below
> > [2]PETSC ERROR: ---------------------  Stack Frames
> > [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [2]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > [2]PETSC ERROR:       is given.
> > [2]PETSC ERROR: [2] DMCreateDecomposition line 854
> > [2]PETSC ERROR: [2] PCSetUp_ASM line 161
> > [2]PETSC ERROR: [2] PCSetUp line 810
> > [2]PETSC ERROR: [2] KSPSetUp line 182
> > [2]PETSC ERROR: [2] KSPSolve line 339
> > [2]PETSC ERROR: [2] SNES_KSPSolve line 4169
> > [2]PETSC ERROR: [2] SNESSolve_LS line 143
> > [2]PETSC ERROR: [2] SNESSolve line 3345
> > [2]PETSC ERROR: --------------------- Error Message
> > [2]PETSC ERROR: Signal received!
> > [2]PETSC ERROR:
> > [2]PETSC ERROR: Petsc Development HG revision:
> -0500
> > [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [2]PETSC ERROR: See docs/index.html for manual pages.
> > [2]PETSC ERROR:
> > [2]PETSC ERROR: ./ex50 on a arch-gnu named
> > [2]PETSC ERROR: Libraries linked from
> > [2]PETSC ERROR: Configure run at Fri Mar 23 22:22:13 2012
> > [2]PETSC ERROR: Configure options --download-blacs --download-fftw
> > [2]PETSC ERROR:
> > [2]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2
> > [cli_2]: aborting job:
> > [3]PETSC ERROR:
> > [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > [3]PETSC ERROR: Try option -start_in_debugger or
> > [3]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSCERROR: or try
> corruption errors
> > [3]PETSC ERROR: likely location of problem given in stack below
> > [3]PETSC ERROR: ---------------------  Stack Frames
> > [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [3]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > [3]PETSC ERROR:       is given.
> > [3]PETSC ERROR: [3] DMCreateDecomposition line 854
> > [3]PETSC ERROR: [3] PCSetUp_ASM line 161
> > [3]PETSC ERROR: [3] PCSetUp line 810
> > [3]PETSC ERROR: [3] KSPSetUp line 182
> > [3]PETSC ERROR: [3] KSPSolve line 339
> > [3]PETSC ERROR: [3] SNES_KSPSolve line 4169
> > [3]PETSC ERROR: [3] SNESSolve_LS line 143
> > [3]PETSC ERROR: [3] SNESSolve line 3345
> > [3]PETSC ERROR: --------------------- Error Message
> > [3]PETSC ERROR: Signal received!
> > [3]PETSC ERROR:
> > [3]PETSC ERROR: Petsc Development HG revision:
> -0500
> > [3]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [3]PETSC ERROR: See docs/index.html for manual pages.
> > [3]PETSC ERROR:
> > [3]PETSC ERROR: ./ex50 on a arch-gnu named
> > [3]PETSC ERROR: Libraries linked from
> > [3]PETSC ERROR: Configure run at Fri Mar 23 22:22:13 2012
> > [3]PETSC ERROR: Configure options --download-blacs --download-fftw
> > [3]PETSC ERROR:
> > [3]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
> > [cli_3]: aborting job:
> /Users/barrysmith/Src/petsc-dev/src/snes/examples/tutorials
> Possible problem with ex50_6, diffs above
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120330/14a335e9/attachment.html>
