[petsc-dev] Weird interaction between VecDuplicate and	VecSetBlockSize
    Lisandro Dalcin
    dalcinl at gmail.com
    Fri Mar 30 11:07:19 CDT 2012
On 30 March 2012 19:00, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 30 March 2012 18:20, Blaise Bourdin <bourdin at lsu.edu> wrote:
>> On Mar 30, 2012, at 10:13 AM, Jed Brown wrote:
>> The PetscLayout is shared. It should probably not be allowed to change block
>> size after duplicating.
Actually, reading my previous reply, I did not expressed it well. I DO
AGREE with you that blocksizes should not be allowed to change once
set for first time. However, I think PETSc do have some code around
(in PC?) relying on this and unashamedly changing the bs of an INPUT
vector! If that was fixed, then we can disable changing bs for Vec.
But as long as we need to support this misfeature, at least let's try
to do better around the lines of my patch (BTW, I'm not sure how to
handle the blocked local to global mapping.... perhaps we can
reconstruct another one?)
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
