[petsc-dev] Weird interaction between VecDuplicate and VecSetBlockSize
Blaise Bourdin
bourdin at lsu.edu
Fri Mar 30 10:00:25 CDT 2012
I am trying to make use of the more advanced features of the hdf5 viewer.
I get the following error when running src/vec/vec/examples/tutorials/ex19.c:
[0]PETSC ERROR: VecLoad_HDF5() line 251 in /opt/HPC/petsc-dev/src/vec/vec/utils/vecio.c Block size 1 specified for vector does not match blocksize in file 2
Upon further investigating, I noticed that if Vec x2 is obtained by duplicating x1, then setting the block size for x2 also sets it for x1. Is this really the desired behavior?
I am attaching an trivial example.
Blaise
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120330/fdecc7c8/attachment.obj>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
