[petsc-dev] GASM
Mark F. Adams mark.adams at columbia.edu
Fri Mar 30 09:04:02 CDT 2012
Thanks, it seems to work but I have a memory leak.  I use:
          ierr = PCGASMSetLocalSubdomains( subpc, sz, is, PETSC_NULL ); CHKERRQ(ierr);
          ierr = PetscFree( is ); CHKERRQ(ierr);
and it looks like the ISs are not getting destroyed in GASM.
On Mar 29, 2012, at 9:35 PM, Dmitry Karpeev wrote:
> Now it should work the way you intended.
> Let me know if it doesn't, though.
> Dmitry.
> On Thu, Mar 29, 2012 at 7:49 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> On Mar 29, 2012, at 11:38 AM, Dmitry Karpeev wrote:
>> On Thu, Mar 29, 2012 at 10:13 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Thu, Mar 29, 2012 at 08:28, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> Back to the original problem: how shall we prevent a shared pc from being gutted by an unprotected PCReset() cascading from a KSPDestroy() on one of the containing ksps?  I can factor out KSPReset_Private()/PCReset_Private() as indicated before, unless there are objections.
>>  What do you think of my suggestion of masking ksp->pc when KSPDestroy calls KSPReset? Then KSPReset does not call PCReset if ksp->pc does not exist.
>> I guess that works too, but I thought your suggestion applied to userland code right before calling KSPDestroy(&ksp)?
>> I suppose that will fix Mark's problem.  Maybe that's the right approach: he got himself into this mess by reusing a pc
>> in the inner ksp, he should know how to extricate himself :-)
> BTW, this is not a matter of being lazy, I need an eigen estimate of the smoothers preconditioned operator.  In the past I created a new PC from the command line database (ugly), but this GASM smoother can not be reconstructed from the database (it uses the AMG aggregates).  I could do a deep copy of the smoother but that would require two setups of the GASM PC, which would be ugly.
> Mark
>> Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120330/25acfc89/attachment.html>
