[petsc-dev] GASM
Dmitry Karpeev
karpeev at mcs.anl.gov
Thu Mar 29 11:45:56 CDT 2012
Pushed: http://petsc.cs.iit.edu/petsc/petsc-dev/rev/76f5543c7e89
On Thu, Mar 29, 2012 at 11:07 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I think Jed is suggesting changing:
> PetscErrorCode KSPDestroy(KSP *ksp)
> PetscErrorCode ierr;
> PetscFunctionBegin;
> if (!*ksp) PetscFunctionReturn(0);
> PetscValidHeaderSpecific((*ksp),KSP_CLASSID,1);
> if (--((PetscObject)(*ksp))->refct > 0) {*ksp = 0;
> PetscFunctionReturn(0);}
> ierr = KSPReset((*ksp));CHKERRQ(ierr);
> to
> PC pc = (*ksp)->pc;
> PetscFunctionBegin;
> pc = (*ksp)->pc;
> (*ksp)->pc = PETSC_NULL;
> (*ksp)->pc = pc;
> Since KSPDestroy() doesn't need to have PCReset() called. This doesn't
> require any special code for users.
> Barry
> On Mar 29, 2012, at 10:38 AM, Dmitry Karpeev wrote:
> > On Thu, Mar 29, 2012 at 10:13 AM, Jed Brown <jedbrown at mcs.anl.gov>
> wrote:
> > On Thu, Mar 29, 2012 at 08:28, Dmitry Karpeev <karpeev at mcs.anl.gov>
> wrote:
> > Back to the original problem: how shall we prevent a shared pc from
> being gutted by an unprotected PCReset() cascading from a KSPDestroy() on
> one of the containing ksps? I can factor out
> KSPReset_Private()/PCReset_Private() as indicated before, unless there are
> objections.
> > What do you think of my suggestion of masking ksp->pc when KSPDestroy
> calls KSPReset? Then KSPReset does not call PCReset if ksp->pc does not
> exist.
> > I guess that works too, but I thought your suggestion applied to
> userland code right before calling KSPDestroy(&ksp)?
> > I suppose that will fix Mark's problem. Maybe that's the right
> approach: he got himself into this mess by reusing a pc
> > in the inner ksp, he should know how to extricate himself :-)
> > Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120329/8bd46a30/attachment.html>
