[petsc-dev] GASM
Dmitry Karpeev karpeev at mcs.anl.gov
Thu Mar 29 10:38:03 CDT 2012
On Thu, Mar 29, 2012 at 10:13 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Mar 29, 2012 at 08:28, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> Back to the original problem: how shall we prevent a shared pc from being
>> gutted by an unprotected PCReset() cascading from a KSPDestroy() on one of
>> the containing ksps?  I can factor out KSPReset_Private()/PCReset_Private()
>> as indicated before, unless there are objections.
>  What do you think of my suggestion of masking ksp->pc when KSPDestroy
> calls KSPReset? Then KSPReset does not call PCReset if ksp->pc does not
> exist.
I guess that works too, but I thought your suggestion applied to userland
code right before calling KSPDestroy(&ksp)?
I suppose that will fix Mark's problem.  Maybe that's the right approach:
he got himself into this mess by reusing a pc
in the inner ksp, he should know how to extricate himself :-)
Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120329/26810bfe/attachment.html>
