[petsc-dev] GASM
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu Mar 29 08:07:01 CDT 2012
On Thu, Mar 29, 2012 at 06:44, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> After this fix  that should cause a more obvious SEGV, but the real
> problem is that a pc that is supposed remain valid is being reset.
It's a bug if you can't call PCReset() more than once without an error.
Also, any SEGV triggered by PETSc is a bug (unless the user passes in
corrupt pointers).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120329/d8a493c6/attachment.html>
