[petsc-dev] How does this compare...
Jack Poulson
jack.poulson at gmail.com
Wed Mar 28 22:52:14 CDT 2012
I dug in a little deeper, and I recommend reading their previous paper:
http://arxiv.org/abs/1011.3534
That paper actually _does_ mention the connection to H-matrix algebra:
"SpAMM is similar to the H-matrix algebra of Hackbusch and co-workers,
where off-diagonal sub-matrices are treated as reduced rank factorizations
(truncated SVD), typically structured and grouped to reflect properties of
the underlying operators. For problems with rapid decay, truncated SVD may
behave in a similar way to simple dropping schemes. SpAMM is different than
the H-matrix algebra as it achieves separation uniquely in the product
space and does not rely on a reduced complexity representation of matrices.
For very slow decay, the H-matrix algebra may certainly offer a path for
intractable problems for which SpAMM is ineffective."
So it seems that the claim is that SpAMM might be more computationally
efficient than H-matrices for fast decay, but ineffective otherwise. Either
way, I don't think it's going to help with classical parallel sparse
matrix-matrix multiplication.
Jack
On Wed, Mar 28, 2012 at 10:28 PM, Jack Poulson <jack.poulson at gmail.com>wrote:
> Actually, please excuse my misreading. The quoted 2-3x speedup was versus
> itself due to hardware prefetch, so it does appear to be asymptotically
> better than SGEMM (they quote the crossover at n ~= 1000).
> Jack
> On Wed, Mar 28, 2012 at 10:23 PM, Jack Poulson <jack.poulson at gmail.com>wrote:
>> I just took a look at the paper and, after reading a bit, I am baffled
>> that there are no citations of the H-matrix literature (Ctrl+F "Hackbusch"
>> turns up nothing...). The paper seems to be in a similar spirit as the
>> well-known H-matrix/H-matrix multiplication algorithms, which take O(N
>> log^2 N) work, for O(1) ranks, but using truncation instead of low-rank
>> approximations in clusters. Since only factors of 2-3x are reported versus
>> SGEMM, which is O(N^3), that tells you that this algorithm (or, at least,
>> its implementation) is O(N^3).
>> I do not think a comparison can be drawn to sparse matrix-matrix multiply
>> algorithms. I believe Gilbert and Buluc have the most recent publication on
>> parallel sparse mat-mat. I have done some work on parallel
>> H-matrix/H-matrix multiplication (the code is here:
>> http://bitbucket.org/poulson/dmhm), but I haven't pushed the paper out
>> the door yet. See http://www.ices.utexas.edu/~poulson/slides/DMHM.pdffor the talk I gave on it. I suspect that the ideas from parallel
>> H-matrix/H-matrix multiplication could be used to generate a
>> communication-efficient sparse mat-mat if it is okay to generate the result
>> in a more general data-sparse form (i.e., low rank blocks) rather than
>> specifically as explicitly classically sparse.
>> Jack
>> On Wed, Mar 28, 2012 at 10:07 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>>> Entire paper discusses SpAMM, and compares with SGEMM.
>>> Sorry, I do not see anything about SpMV.
>>> Hong
>>> On Wed, Mar 28, 2012 at 9:52 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Wed, Mar 28, 2012 at 9:39 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>>>>> Matt:
>>>>>> to the new scalable MatMatMult() that is done in PETSc? Is it
>>>>>> possible to even compare
>>>>>> the flop rates sensibly?
>>>>>> http://arxiv.org/abs/1203.1692
>>>>> "An Optimized Sparse Approximate Matrix Multiply"
>>>>> computes Approximate matrix product for matrices with decay
>>>>> It is for special application in chemistry(?),
>>>>> not applicable for general sparse matrix product.
>>>>> No comparison can be drawn to petsc's C=A*B.
>>>> This is the wrong conclusion. What he does is sparsify the result, so
>>>> he is
>>>> computing SOME sort of sparse matrix-vector product. The question is:
>>>> Does his SpMV use the same algorithm as PETSc?
>>>> That is why I asked.
>>>> Matt
>>>>> Hong
>>>>>> This is what Jeff is planning on using in his SciDAC.
>>>>>> Matt
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120328/e28a4625/attachment.html>
