[petsc-dev] How does this compare...
Jack Poulson jack.poulson at gmail.com
Wed Mar 28 22:23:53 CDT 2012
I just took a look at the paper and, after reading a bit, I am baffled that
there are no citations of the H-matrix literature (Ctrl+F "Hackbusch" turns
up nothing...). The paper seems to be in a similar spirit as the well-known
H-matrix/H-matrix multiplication algorithms, which take O(N log^2 N) work,
for O(1) ranks, but using truncation instead of low-rank approximations in
clusters. Since only factors of 2-3x are reported versus SGEMM, which is
O(N^3), that tells you that this algorithm (or, at least, its
implementation) is O(N^3).
I do not think a comparison can be drawn to sparse matrix-matrix multiply
algorithms. I believe Gilbert and Buluc have the most recent publication on
parallel sparse mat-mat. I have done some work on parallel
H-matrix/H-matrix multiplication (the code is here:
http://bitbucket.org/poulson/dmhm), but I haven't pushed the paper out the
door yet. See http://www.ices.utexas.edu/~poulson/slides/DMHM.pdf for the
talk I gave on it. I suspect that the ideas from parallel H-matrix/H-matrix
multiplication could be used to generate a communication-efficient sparse
mat-mat if it is okay to generate the result in a more general data-sparse
form (i.e., low rank blocks) rather than specifically as explicitly
classically sparse.
Jack
On Wed, Mar 28, 2012 at 10:07 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Entire paper discusses SpAMM, and compares with SGEMM.
> Sorry, I do not see anything about SpMV.
> Hong
> On Wed, Mar 28, 2012 at 9:52 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Mar 28, 2012 at 9:39 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>>> Matt:
>>>> to the new scalable MatMatMult() that is done in PETSc? Is it possible
>>>> to even compare
>>>> the flop rates sensibly?
>>>>   http://arxiv.org/abs/1203.1692
>>> "An Optimized Sparse Approximate Matrix Multiply"
>>> computes  Approximate matrix product for matrices with decay
>>> It is for special application in chemistry(?),
>>> not applicable for general sparse matrix product.
>>> No comparison can be drawn to petsc's C=A*B.
>> This is the wrong conclusion. What he does is sparsify the result, so he
>> is
>> computing SOME sort of sparse matrix-vector product. The question is:
>>    Does his SpMV use the same algorithm as PETSc?
>> That is why I asked.
>>     Matt
>>> Hong
>>>> This is what Jeff is planning on using in his SciDAC.
>>>>       Matt
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120328/a5223080/attachment.html>
