[petsc-dev] dates of last change on PETSc web pages
Jed Brown
jedbrown at mcs.anl.gov
Tue Mar 20 22:27:26 CDT 2012
On Tue, Mar 20, 2012 at 22:15, Barry Smith <bsmith at mcs.anl.gov> wrote:
> http://mercurial.selenic.com/wiki/KeywordExtension seems to be what we
> should use. It appears that the hg makes sure the working copy always has
> the value (Date of last change in our case) in files one sees.
I don't really want to read diffs of all those dates.
> Proving Linus thinks like Satish:
> Not sure this will ever be in Git. To quote Linus: "The whole notion of
> keyword substitution is just totally idiotic. It's trivial to do "outside"
> of the actual content tracking, if you want to have it when doing release
> trees as tar-balls etc."
Are we that concerned with src/docs/website being unnamed before writing
the tarball?
I think the date should go into the generated man pages while they are
generated because that is when you know the modification date of the file.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120320/b1b40341/attachment.html>
