[petsc-dev] GAMG hiding MG -help
Mark F. Adams
mark.adams at columbia.edu
Mon Mar 19 18:58:32 CDT 2012
I just found that GAMG seems to be hiding MG's parameters when -help is used.
I have this code in my PCSetUp_GAMG:
/* should be called in PCSetFromOptions_GAMG(), but cannot be called prior to PCMGSetLevels() */
ierr = PetscObjectOptionsBegin((PetscObject)pc);CHKERRQ(ierr);
ierr = PCSetFromOptions_MG( pc ); CHKERRQ(ierr);
ierr = PetscOptionsEnd();CHKERRQ(ierr);
if (mg->galerkin != 2) SETERRQ(wcomm,PETSC_ERR_USER,"GAMG does Galerkin manually so the -pc_mg_galerkin option must not be used.");
Which seems funky, but I think I cloned this or had some reason to put this here. And I set:
pc->ops->setfromoptions = PCSetFromOptions_GAMG;
in PCCreate_GAMG.
Any advice on how I should fix this?
