[petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
Sean Farley sean at mcs.anl.gov
Mon Mar 19 10:53:24 CDT 2012
> It's a normal int, not a PetscInt, so at least it will always fit in that
> pointer variable.
> You can silence the warning by changing the line from
>     leftarray[0] = (point) i; // The array length.
> to
>     leftarray[0] = (point) (PETSC_UINTPTR_T)i; // The array length.
What I don't understand, is that with all this work done (thanks Matt!) why
is it bundled with PETSc and not as a forked project? I mean, ctetgen seems
like it would have value for other projects and most of the work is just
scrubbing out the C++ (which, again, Matt just did the bulk of!). Why not
just make an interface to it? This would have the added bonus of solving
the license quirks (and, yes, Matt, there is a difference between having a
fork / linking vs. *bundling* the code).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120319/e7dbe146/attachment.html>
