[petsc-dev] I do not think this is the right solution
Matthew Knepley
knepley at gmail.com
Sun Mar 18 18:44:01 CDT 2012
On Sun, Mar 18, 2012 at 6:37 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Mar 18, 2012 at 18:24, Matthew Knepley <knepley at gmail.com> wrote:
>> In the alternate model, you call MatAssemblyBegin/End() when the matrix
>> is marked as unassembled. Its easy to check this flag, so the user
>> will not be confused. Barry is correct that the flag reset is not
>> collective, so that query would have to be.
> We should think as though we are in a world where the query costs as much
> as the assembly itself because that is a better approximation of reality
> than the alternatives.
>> I do not think "fragile" is an accurate characterization because failure
>> is immediate when trying to use a function that requires assembly, and it
>> also obvious what the fix is, to assemble the matrix.
> It's not collective.
>> You might mean that the existing model is more intuitive. I disagree
>> since it is currently impossible to do something simple like
>> chop out small values from a matrix.
> MatGetArray()
Of course I fucking tried that first. It does not work.
Matt
> Or you actually want to remove them from the nonzero pattern? In that
> case, you definitely have to assemble, which means there is a new
> partly-assembled state (locally consistent, but not globally).
>> The proposal is to augment the current model with MatGetRowWrite(). This
>> would mean
>> not only adding to the interface, but writing all the code to put values
>> back into the matrix if the row is a copy. I think it is more
>> intuitive to allow the user to SetValues() if the nonzero pattern is
>> unchanged and no values need to be communicated.
> MatSetValues() is a very permissive interface for modifying data in-place.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120318/a9c2c2a9/attachment.html>
