[petsc-dev] I do not think this is the right solution
    Matthew Knepley
    knepley at gmail.com
    Sun Mar 18 15:07:16 CDT 2012
On Sun, Mar 18, 2012 at 2:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 18, 2012, at 12:09 PM, Matthew Knepley wrote:
> > On Sun, Mar 18, 2012 at 11:52 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > On Mar 18, 2012, at 11:39 AM, Matthew Knepley wrote:
> > > https://bitbucket.org/petsc/petsc-dev/changeset/7ae47bfbd6e9
> > > Why are we using the assembled flag to determine whether garray and
> colmap
> > > should be created? That seems like an abuse of the flag. Shouldn't we
> check
> > > for these when we need them?
> >   This has always been the use of that flag since day one. That is the
> reason for the existence of that flag. Now you want to change the meaning
> of the flag.
> >   Since your MatGetRow() MatSetValues() paradigm only works properly if
> no new nonzeros are introduced (otherwise people will get assembled errors
> after they've put in some values) what is wrong with my proposed solution
> of MatGetRowWrite() which is the correct interface for changing some values
> in the row but not the nonzero structure.
> > Your own metric. It complicates the interface. I have to know that I
> only want to change existing nonzeros, when it is
> > perfectly easy for SetValues() to detect this AND I already went and
> found all the places where this happens.
>    Found all the places where what happens?  You introduced a bug, for
> example mat/examples/tests/ex37.c with multiple processes crashed after you
> "found all the places where this happens".  I wasted hours tracking down
> the problem from you missing "one of the places where this happens". And
> how come you didn't change all the other MatSetValuesXXX() that also use
> the same assembled flags? I don't think you came close to "found all the
> places where this happened".
Let me clarify. I did not find your completely undocumented "feature" that
has "always been that way". I found the places where
values would have to be communicated, which is what the documentation says
the assembly does.
>  PETSc Mat has ALWAYS had a simple well-defined policy of a phase where
> you set values in the matrix and a separate phase where you can access
> values; it has served us very well over the years. Now you suddenly what to
> change this policy "sometimes".
>   I also think you misunderstand my proposal that SAFELY gives you
> everything you want in a clean way that does not confuse the setvalues
> phase and the accessvalues phase.
>    MatGetRowWrite(mat,PetscInt row,PetscInt *nz, const PetscInt
> **indices,PetscScalar **values)
>    /*   here I have code that changes some of the entries in values; note
> I cannot change the indices since they are const */
>     MatRestoreRowWrite(mat,PetscInt row,PetscInt *nz, const PetscInt
> **indices,PetscScalar **values)  the routine puts the changed values back
> into the underly Mat. no chance of changing nonzero structure.
>    With your model
>    MatGetRow(mat,PetscInt row,PetscInt *nz, const PetscInt **indices,const
>     MatRestoreRow(mat,PetscInt row,PetscInt *nz, const PetscInt
> **indices,const PetscScalar **values)
>    MatSetValues(mat,row ....)
>     there is no mechanism to insure that the user only sets values that
> already existed in the matrix which may trigger a change in the nonzero
> structure which means the next call to MatGetRow() will fail. Plus it
> posses the problem why can you sometimes mix accessing values and calling
> MatSetValues() but sometimes not? Having one simple policy on separating
> the phases is valuable and should be kept.
Here is what I do not understand. Isn't it obvious when an insertion
changes nonzero structure? Shouldn't we fix this obvious functionality
hole rather than complicating the interface?
I just changed the code I had to Assemble() all over the place.
   Matt
>   Barry
>    Barry
> >    Matt
> >   Barry
> > >    Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120318/7aa8a44e/attachment.html>
