[petsc-dev] I do not think this is the right solution
Matthew Knepley
knepley at gmail.com
Sun Mar 18 12:09:18 CDT 2012
On Sun, Mar 18, 2012 at 11:52 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 18, 2012, at 11:39 AM, Matthew Knepley wrote:
> > https://bitbucket.org/petsc/petsc-dev/changeset/7ae47bfbd6e9
> > Why are we using the assembled flag to determine whether garray and
> colmap
> > should be created? That seems like an abuse of the flag. Shouldn't we
> check
> > for these when we need them?
> This has always been the use of that flag since day one. That is the
> reason for the existence of that flag. Now you want to change the meaning
> of the flag.
> Since your MatGetRow() MatSetValues() paradigm only works properly if no
> new nonzeros are introduced (otherwise people will get assembled errors
> after they've put in some values) what is wrong with my proposed solution
> of MatGetRowWrite() which is the correct interface for changing some values
> in the row but not the nonzero structure.
Your own metric. It complicates the interface. I have to know that I only
want to change existing nonzeros, when it is
perfectly easy for SetValues() to detect this AND I already went and found
all the places where this happens.
Matt
> Barry
> > Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120318/11b1e72e/attachment.html>
