[petsc-dev] Revamping the multilevel KSP interface
Jed Brown
jedbrown at mcs.anl.gov
Sat Mar 17 22:41:26 CDT 2012
On Sat, Mar 17, 2012 at 21:34, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Is grid sequencing the only use case? What is the plan with grid
> sequencing for linear problems? Are the people who really want to do that
> capable of using SNES with KSPONLY? That would also make it easier to use a
> higher order prolongation the first time a given grid is reached, but use
> standard interpolants in subsequent cycles (as Achi does for the best work
> estimates).
And does anyone prefer this interface where they set a callback to build
the RHS instead of calling the function themselves (or constructing the RHS
any way they please)? I know it makes for a somewhat slick example, but the
user has to interact with a Vec anyway to get the solution out.
http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex25.c.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120317/d41d4376/attachment.html>
