[petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
Mark F. Adams
mark.adams at columbia.edu
Sat Mar 17 15:32:25 CDT 2012
On Mar 17, 2012, at 2:03 PM, Jed Brown wrote:
> On Sat, Mar 17, 2012 at 12:43, Mark F. Adams <mark.adams at columbia.edu> wrote:
> I am looking for prescriptions. Several of my problems are local functions, I guess I can make these static (I assume this works for functions). I made some attempt to name space some of these (gamg_setup_events) and others are tools that need to be global (createSimpleGraph) -- how should I fix these? PetscCreateSimpleGraph?
> If it doesn't have a man page, it's not a public interface, so don't let it grow outside of its current use environment. If it's in the same file, just make it static. If it needs to be shared between multiple implementation files, use the namespace you are working under, e.g. PCGAMGCreateSimpleGraph() or PCGAMGCreateSimpleGraph_Private() to make it more explicit that this is an internal interface.
done, but it won't show up until I check in my current repo, which could be a week.
> I don't understand why you have this gamg_setup_events. These event names are anything but intuitive in the sense that they don't stand alone and is denormalized (which makes it non-grepable). I also don't think it makes sense for GAMG to have its own classid since it's not a new PetscObject. I suggest registering with
I bracket code that make sense for analysis, and not necessarily at function boundaries. This is not standard so I will hide them with a private #define.
> PetscLogEventRegister("PCGAMGCreateProl", PC_CLASSID, &PC_GAMGCreateProl);
OK, I will instrument the four parts of the framework (graph,coarsen,prolongator, opt-prol) for 'AGG' and 'GEO', in this way.
> and similarly for other events
> PCGAMGCreateProl
> PCGAMGGraph
> PCGAMGGeoGrowSupp
> PCGAMGGeoTriangle
> PCGAMGPartLevel
> In most cases, the event names should approximately (subject to length constraints) match the routines that implement those events.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120317/2346dc31/attachment.html>
