[petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
Jed Brown
jedbrown at mcs.anl.gov
Sat Mar 17 09:58:24 CDT 2012
*Every* symbol (both functions and data) with extern linkage *must* be
namespaced to avoid link- or run-time conflicts when the user (or any other
library to be used in the same application) defines their own variable
called "rankkey" or "actions" or "objects" or "ListCreate" or
"createLevel", etc. No exceptions.
Either use static linkage or namespace the symbols. Some old code was
sloppy about this (and needs to be fixed), but we really need to be careful
to never do this is new code.
You can build a libpetsc.a (--with-shared-libraries=0) and search for any
defined symbols (T, B, R, C, D) that are not namespaced. Some examples
below.
*pthread.c:*
00000000000004c5 T DoCoreAffinity
0000000000000232 T FuncFinish
0000000000000010 B MainThreadCoreAffinity
0000000000000100 R ThreadAffinityPolicyTypes
0000000000000008 B ThreadCoreAffinity
0000000000000060 R ThreadSynchronizationTypes
0000000000000004 C rankkey
0000000000000018 B threadranks
plog.c:
0000000000000000 B actions
0000000000000010 B logActions
0000000000000014 B logObjects
0000000000000038 D maxActions
000000000000003c D maxObjects
0000000000000018 B numActions
000000000000001c B numObjects
0000000000000020 B numObjectsDestroyed
0000000000000008 B objects
0000000000000040 D traceblanks
00000000000000d8 B tracefile
00000000000000e0 B tracelevel
0000000000000060 D tracespace
00000000000000e8 B tracetime
*ctetgen.c:*
000000000000ade7 T ArrayPoolCreate
000000000000b979 T ArrayPoolDestroy
000000000000b0cf T ArrayPoolGetBlock
000000000000b6f7 T ArrayPoolNewIndex
000000000000ac41 T ArrayPoolRestart
0000000000006cfe T ListAppend
00000000000082ec T ListClear
00000000000069c7 T ListCreate
00000000000077ad T ListDelete
0000000000008491 T ListDestroy
0000000000007ae2 T ListHasItem
000000000000718e T ListInsert
0000000000007ea0 T ListItem
0000000000007cf5 T ListLength
00000000000080c6 T ListSetItem
00000000000096af T MemoryPoolAlloc
000000000000a415 T MemoryPoolCreate
0000000000009a9d T MemoryPoolDealloc
000000000000a827 T MemoryPoolDestroy
000000000000a1ed T MemoryPoolRestart
0000000000009c6a T MemoryPoolTraversalInit
0000000000009e6e T MemoryPoolTraverse
0000000000008868 T QueueCreate
0000000000009324 T QueueDestroy
0000000000008c23 T QueueLength
00000000000090b0 T QueuePop
0000000000008dd5 T QueuePush
0000000000003f06 T lu_decmp
0000000000004303 T lu_solve
*gamg.c/agg.c/geo.c/tools.c:*
0000000000000926 T createLevel
0000000000000050 C gamg_setup_events
00000000000054c6 T formProl0
0000000000002989 T smoothAggs
0000000000000629 T geo_mg_compare
00000000000012f0 T getGIDsOnSquareGraph
0000000000001292 T triangulateAndFormProl
0000000000000629 T createSimpleGraph
00000000000028fe T getDataWithGhosts
0000000000001415 T scaleFilterGrap
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120317/01939909/attachment.html>
