[petsc-dev] Calls to DMCreateFieldIS missing from fieldsplit.c
Jed Brown
jedbrown at mcs.anl.gov
Fri Mar 16 15:12:08 CDT 2012
On Fri, Mar 16, 2012 at 15:06, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> The code is totally different. I'll fix it.
The type (const char ***) is also incorrect for this semantic.
Unfortunately, C++ forces us to cast to void* just to implement PetscFree()
and that discards const. If we could write in C, we could use the implicit
conversion to void* without discarding const.
There are workarounds like
#define PetscCast(type,var) static_cast<type>(var)
that would not discard the const qualifier.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120316/287e3d27/attachment.html>
