[petsc-dev] Calls to DMCreateFieldIS missing from fieldsplit.c
Fri Mar 16 15:03:49 CDT 2012
On Fri, Mar 16, 2012 at 2:50 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Mar 16, 2012 at 12:53, Jungho Lee <julee at mcs.anl.gov> wrote:
>> On Fri, Mar 16, 2012 at 12:50 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> > Yes, this definitely worked when it was put in and most of the time
>> since. I
>> > can debug now if you like.
>> Yes, please do, and keep us updated. Thanks.
> The problem is that when Matt added DMCreateFieldIS() (replacing my
> earlier implementation that only worked with DMComposite), he did not
> document how the array was supposed to be freed and his two implementations
> do not agree. In fact, one of the branches is definitely incorrect because
> it returns a dangling pointer to an old stack frame.
> Matt, should the string names all be copied (so the caller of this
> function frees the array *and* every individual field name) or should those
> char* just refer to the field names, the memory for which is managed by the
> DM?
They are all copied. That is how DMComplex works. I was probably not
careful with Composite.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120316/01023012/attachment.html>
