[petsc-dev] petsc release soon
Jed Brown
jedbrown at mcs.anl.gov
Tue Mar 13 09:52:00 CDT 2012
On Tue, Mar 13, 2012 at 09:42, Matthew Knepley <knepley at gmail.com> wrote:
> That is a bad way to organize things. We already have the filesystem for
> this kind of information.
We've been through this before. It's useful to have a way to temporarily
deactivate some part of the build. Also, the simple attribute of having
every build system nominally produce the same result. Note that VIRSAUG is
not registered, so even though you made it compile, it still isn't
accessible or functional.
>>> What the hell is this. Either delete it or build it. I will fix this.
>> Someone needs to fix VIRSAUG
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/31c8ce4101dd
> I fixed it and pushed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120313/7106167d/attachment.html>
