[petsc-dev] petsc release soon
Jed Brown
jedbrown at mcs.anl.gov
Tue Mar 13 09:31:10 CDT 2012
On Tue, Mar 13, 2012 at 09:25, Matthew Knepley <knepley at gmail.com> wrote:
> I don't use the makefiles.
The makefiles are the canonical statement of what is part of the build and
what isn't. You should parse them to decide what builder.py is supposed to
build. It is very easy to do this in Python, see
distutils.sysconfig.parse_makefile and config/cmakegen.py.
> What the hell is this. Either delete it or build it. I will fix this.
Someone needs to fix VIRSAUG
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/31c8ce4101dd
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120313/5b2f0dcd/attachment.html>
