[petsc-dev] MatCopy to zero preallocated matrix
Matthew Knepley
knepley at gmail.com
Thu Mar 1 17:06:53 CST 2012
On Thu, Mar 1, 2012 at 5:03 PM, Vaclav Hapla <vaclav.hapla at vsb.cz> wrote:
> Dear PETSc team,
> why I am not able to do this:
> MatCreate(PETSC_COMM_SELF, &Kreg);
> MatSetSizes(Kreg,m,n,m,n);
> MatSetType(Kreg, MATSEQAIJ);
> MatSeqAIJSetPreallocation(**Kreg,0,nnz);
> MatAssemblyBegin(Kreg, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd( Kreg, MAT_FINAL_ASSEMBLY);
> PetscFree(nnz);
> PetscInt nz_Kreg;
> MatGetRow(Kreg, 0, &nz_Kreg, PETSC_IGNORE, PETSC_IGNORE);
> PetscPrintf(PETSC_COMM_SELF, "nnz %d Kreg %d\n", nnz[0], nz_Kreg); //
> prints nnz 11 Kreg 0 !!!
> MatCopy(K_loc, Kreg, DIFFERENT_NONZERO_PATTERN); //fails: New nonzero at
> (0,0) caused a malloc!
I think you want
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatDuplicate.html
which does it in one line.
Matt
> PETSc complains about new nonzero - not surprisingly because
> MatAssemblyBegin/End filters zeros as I understand.
> But when I comment out MatAssemblyBegin/End, MatCopy complains that it is
> only for assembled matrices.
> I think that to call MatSetValues on all allocated nonzeros just to make
> them survive MatAssemblyBegin/End or to replace MatCopy call by loop over
> raw array is both quite awkward.
> Maybe one should be able to turn the filter in MatAssemblyBegin/End off.
> Or is there any other way out?
> BTW, what I need is to make a copy Kreg of given matrix K_loc but with few
> additional preallocated positions which are filled later. Is there some
> other convenient solution?
> Cheers,
> Vaclav Hapla
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120301/80013715/attachment.html>
