[petsc-dev] setup.py for building Python extensions involving PETSc
Chris Kees
cekees at gmail.com
Thu Mar 1 08:56:11 CST 2012
This may be of interest to people developing in Python and C/C++. I worked
out a simple hack to use the petsc4py configuration to build Python
extension modules with the correct petsc compilers and options. We had
been doing this using some makefile tricks, but our approach wasn't as
reliable as Lisandro's configuration of petsc4py. I had to hack two of the
build_ext functions. You still have to give setup.py the
--petsc-dir/--petsc-arch arguments. It might be a nice feature to
install something similar in petsc4py so one could just do 'from petsc4py
import PetscExtension'.
Chris
setup.py
from distutils.core import setup
sys.path.append('/path_to_petsc4py')
from conf.petscconf import Extension as PetscExtension
from conf.petscconf import build_ext as petsc_build_ext
from conf.petscconf import config, build, build_src
from conf.petscconf import test, sdist
class my_build_ext(petsc_build_ext):
def build_configuration(self, arch_list):
from distutils.util import split_quoted, execute
template, variables = self.get_config_data(arch_list)
config_data = template % variables
build_lib = self.build_lib
dist_name = self.distribution.get_name()
config_file = os.path.join(build_lib, dist_name,'petsc.cfg')#cek
hack
def write_file(filename, data):
fh = open(filename, 'w')
try: fh.write(config_data)
finally: fh.close()
execute(write_file, (config_file, config_data),
msg='writing %s' % config_file,
verbose=self.verbose, dry_run=self.dry_run)
def _copy_ext(self, ext):
from copy import deepcopy
extclass = ext.__class__
fullname = self.get_ext_fullname(ext.name)
modpath = str.split(fullname, '.')
pkgpath = os.path.join('', *modpath[0:-1])
name = modpath[-1]
sources = list(ext.sources)
newext = extclass(name, sources)
newext.__dict__.update(deepcopy(ext.__dict__))
newext.name = name
pkgpath=''#cek hack
return pkgpath, newext
setup(name='proteus',
ext_package='proteus',
package_data = {'proteus' : ['petsc.cfg'],},
cmdclass = {'config' : config,
'build' : build,
'build_src' : build_src,
'build_ext' : my_build_ext,
'test' : test,
'sdist' : sdist,
ext_modules=[PetscExtension('flcbdfWrappers',
['proteus/flcbdfWrappersModule.cpp','proteus/mesh.cpp','proteus/meshio.cpp'],
define_macros=[('PROTEUS_TRIANGLE_H',PROTEUS_TRIANGLE_H),
('PROTEUS_SUPERLU_H',PROTEUS_SUPERLU_H),
('CMRVEC_BOUNDS_CHECK',1),
('MV_VECTOR_BOUNDS_CHECK',1),
('PETSCVEC_BOUNDS_CHECK',1),
('F77_POST_UNDERSCORE',1),
('USE_BLAS',1)],
include_dirs=['include',numpy.get_include(),PROTEUS_SUPERLU_INCLUDE_DIR,PROTEUS_TRIANGLE_INCLUDE_DIR]+PROTEUS_DAETK_INCLUDE_DIR+PROTEUS_PETSC_INCLUDE_DIRS+
[PROTEUS_MPI_INCLUDE_DIR],
library_dirs=[PROTEUS_DAETK_LIB_DIR]+PROTEUS_PETSC_LIB_DIRS+[PROTEUS_MPI_LIB_DIR],
libraries=['m',PROTEUS_DAETK_LIB]+PROTEUS_PETSC_LIBS+PROTEUS_MPI_LIBS,
extra_link_args=PROTEUS_EXTRA_LINK_ARGS,
extra_compile_args=PROTEUS_EXTRA_COMPILE_ARGS)])
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120301/523eee73/attachment.html>
