[petsc-dev] Problematic Merge of FieldSplit
Matthew Knepley
knepley at gmail.com
Tue Jun 26 06:13:03 CDT 2012
It turns out that 'hg rollback' during an 'hg rebase' does not do what I
thought it did. I think
everything is cleaned up with this push, but if you made FS changes in the
past month, please
check that it is doing what you want with prefixes, etc.
Now, nested fieldsplits from the command line work, ala
-ksp_type fgmres
-pc_type fieldsplit -pc_fieldsplit_type additive
-pc_fieldsplit_0_fields 0,1
-fieldsplit_0_pc_type fieldsplit
-fieldsplit_0_pc_fieldsplit_type schur
-fieldsplit_0_pc_fieldsplitschur_factorization_type full
-fieldsplit_0_fieldsplit_velocity_ksp_type preonly
-fieldsplit_0_fieldsplit_velocity_pc_type lu
-fieldsplit_0_fieldsplit_pressure_ksp_rtol 1e-10
-fieldsplit_0_fieldsplit_pressure_pc_type jacobi
-pc_fieldsplit_1_fields 2
-fieldsplit_temperature_ksp_type preonly
-fieldsplit_temperature_pc_type lu
A split with only one field gets the field name, and otherwise a split
number.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120626/9ebd0e3a/attachment.html>
