[petsc-dev] PetscLogView vs. -log_summary
Thu Jun 21 23:00:40 CDT 2012
On Jun 21, 2012, at 10:46 PM, Matthew Knepley wrote:
> On Thu, Jun 21, 2012 at 4:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > That works, yes. Is the issue that stages / events need to be activated a priori, which is not possible when PetscLogView is only called at the end of the program?
> > Crap.
>    Matt,  why is this "Crap"   its completely reasonable that if you want to have logging from program control that you have to turn it on programatically?
> Crap, because I should have remembered earlier.
   FAQ or some other mechanism to "remember this". We can't be relying on our memories :-)
   Actually, why not have PetscLogView() print an error message if PetscLogBegin() was not previously called? Instead of just not have data to display? Then we won't need to remember anything?
   Barry
>    Matt
> > If you do not provide -log_summary, you need PetscLogBegin() at the beginning.
> >    Matt
> > The caveat is that I am assuming that when using log_summary, the log is written as part of PetscFinalize, so that if a job is killed by the sceduler or the user, there is no way to get an idea of the performances. I like to print the log every so often.
> > Blaise
> > Department of Mathematics and Center for Computation & Technology
> > Louisiana State University, Baton Rouge, LA 70803, USA
> > Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> -- Norbert Wiener
