[petsc-dev] Problem with VecLoad and .info files
Sun Jun 10 09:06:31 CDT 2012
Can you set a different prefix for each vector? (I'm surprised that more
people don't run into this problem of incompatibility, but don't know an
easy generic way to fix the problem.)
$ cat vector.dat.info
-vecload_block_size 1
-vecload_block_size 3
On Sun, Jun 10, 2012 at 8:37 AM, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> I think I found another bug related to Vec blocksize...
> It looks like loading vectors with different block sizes from a binary
> fine is broken in petsc-3.3:
> try the attached example:
> iMac:Misc blaise$ ./TestVecLoad-dev -ndofU 1 -ndofV 3  -nx 2 -ny 2 -mode 0
> Vector Object:UVec 1 MPI processes
>  type: mpi
> Process [0]
> 0
> 10
> 1
> 11
> Vector Object:VVec 1 MPI processes
>  type: mpi
> Process [0]
> 0
> -100
> -200
> -10
> -110
> -210
> -1
> -101
> -201
> -11
> -111
> -211
> Writing vectors to file
> iMac:Misc blaise$ ./TestVecLoad-dev -ndofU 1 -ndofV 3  -nx 2 -ny 2 -mode 1
> Reading vectors from file
> Processor [0] M 2 N 2 m 1 n 1 w 1 s 1
> X range of indices: 0 2, Y range of indices: 0 2
> Processor [0] M 2 N 2 m 1 n 1 w 3 s 1
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Arguments are incompatible!
> [0]PETSC ERROR: Local size 4 not compatible with block size 3!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 0, unknown
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./TestVecLoad-dev on a Darwin-gc named iMac.local by
> blaise Sun Jun 10 08:35:07 2012
> [0]PETSC ERROR: Libraries linked from
> /opt/HPC/petsc-3.3/Darwin-gcc4.2-g/lib
> [0]PETSC ERROR: Configure run at Fri Jun  8 22:01:00 2012
> [0]PETSC ERROR: Configure options CFLAGS=-Wno-unused --download-hdf5=1
> --download-metis=1 --download-parmetis=1 --download-sowing=1
> --download-triangle=1 --with-cmake=cmake --with-debugging=1
> --with-gnu-compilers=1 --with-mpi-dir=/opt/HPC/mpich2-1.4.1p1-gcc4.2
> --with-pic --with-shared-libraries=1 --with-x11=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscLayoutSetBlockSize() line 459 in
> /opt/HPC/petsc-3.3/src/vec/vec/impls/mpi/pmap.c
> [0]PETSC ERROR: VecSetBlockSize() line 1526 in
> /opt/HPC/petsc-3.3/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: VecLoad_Binary() line 104 in
> /opt/HPC/petsc-3.3/src/vec/vec/utils/vecio.c
> [0]PETSC ERROR: VecLoad_Default() line 348 in
> [0]PETSC ERROR: VecLoad() line 1111 in
> [0]PETSC ERROR: main() line 86 in TestVecLoad-dev.c
> application called MPI_Abort(MPI_COMM_WORLD, 75) - process 0
> [unset]: aborting job:
> but if one destroys the vector.dat.info file, everything seems fine:
>  type: mpi
> Process [0]
> 0
> 10
> 1
> 11
>  type: mpi
> Process [0]
> 0
> -100
> -200
> -10
> -110
> -210
> -1
> -101
> -201
> -11
> -111
> -211
> iMac:Misc blaise$ rm vector.dat.info
>  type: seq
> 0
> 10
> 1
> 11
>  type: seq
> 0
> -100
> -200
> -10
> -110
> -210
> -1
> -101
> -201
> -11
> -111
> -211
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120610/79438543/attachment.html>
