[petsc-dev] does petsc filter out zeros in MatSetValues?
Xuefei Yuan (Rebecca)
xyuan at lbl.gov
Thu Jan 26 23:05:05 CST 2012
Hello Mark,
Actually I have tried those options for a sequential run where I need to use superlu to get the condition number of some matrix.
In the dev version,
ierr = DMCreateMatrix(DMMGGetDM(dmmg), MATAIJ, &jacobian);CHKERRQ(ierr);
ierr = MatSetOption(jacobian, MAT_IGNORE_ZERO_ENTRIES, PETSC_TRUE);CHKERRQ(ierr);
And in the options file,
-dm_preallocate_only
is added.
This is totally fine when np=1, however, when I use multiple processors, there are some memory corruption happened.
For example, the number of true nonzeros for 65536 size matrix is 1,470,802. the output (&) is for np=1 with the following PETSc related options:
-snes_ksp_ew true
-snes_monitor
-snes_max_it 1
-ksp_view
-mat_view_info
-ksp_type preonly
-pc_type lu
-pc_factor_mat_solver_package superlu
-mat_superlu_conditionnumber
-mat_superlu_printstat
However, when np=2, the number of nonzeros changes to 3,366,976 with the following PETSc related options. (*) is the output file.
-snes_ksp_ew true
-snes_monitor
-ksp_view
-mat_view_info
-ksp_type preonly
-pc_type lu
-pc_factor_mat_solver_package superlu_dist
*************petsc-Dev = yes*****************
******* start solving for time = 1.00000 at time step = 1******
0 SNES Function norm 1.242539468950e-02
Matrix Object: 1 MPI processes
type: seqaij
rows=65536, cols=65536
total: nonzeros=1470802, allocated nonzeros=2334720
total number of mallocs used during MatSetValues calls =0
not using I-node routines
Recip. condition number = 4.345658e-07
MatLUFactorNumeric_SuperLU():
Factor time = 42.45
Factor flops = 7.374620e+10 Mflops = 1737.25
Solve time = 0.00
Number of memory expansions: 3
No of nonzeros in factor L = 32491856
No of nonzeros in factor U = 39390974
No of nonzeros in L+U = 71817294
L\U MB 741.397 total MB needed 756.339
type: seqaij
package used to perform factorization: superlu
total: nonzeros=0, allocated nonzeros=0
SuperLU run parameters:
Equil: NO
ColPerm: 3
IterRefine: 0
SymmetricMode: NO
DiagPivotThresh: 1
PivotGrowth: NO
ConditionNumber: YES
RowPerm: 0
ReplaceTinyPivot: NO
PrintStat: YES
lwork: 0
MatSolve__SuperLU():
Factor time = 42.45
Solve time = 0.59
Solve flops = 1.436365e+08 Mflops = 243.45
1 SNES Function norm 2.645145585949e-04
Matrix Object: 2 MPI processes
type: mpiaij
total: nonzeros=3366976, allocated nonzeros=6431296
type: mpiaij
total: nonzeros=3366976, allocated nonzeros=3366976
using I-node (on process 0) routines: found 8192 nodes, limit used is 5
Input Error: Incorrect objective type.
At column 0, pivotL() encounters zero diagonal at line 708 in file symbfact.c
Moreover, When I use valgrind with --leak-check=yes --track-origins=yes, there are 441 errors from 219 contexts in PetscInitialize() before calling SNESSolve(). Is this normal for dev?
Thanks very much!
Best regards,
Rebecca
On Jan 26, 2012, at 5:06 PM, Jed Brown wrote:
> On Thu, Jan 26, 2012 at 19:00, Mark F. Adams <mark.adams at columbia.edu> wrote:
> I'm guessing that PETSc recently changed and now filters out 0.0 in MatSetValues ... is this true?
> Did the option MAT_IGNORE_ZERO_ENTRIES get set somehow?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120126/e7d7fa7b/attachment.html>
