[petsc-dev] Documentation comment support
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Dec 23 21:21:37 CST 2012
On Dec 23, 2012, at 9:16 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Dec 23, 2012 at 9:07 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I do not want to give up on namedest yet. There are some suggestions here:
> http://sbml.org/Forums/index.php?t=tree&goto=7873&rid=0
> 1) The guys says to try the Acrobat plugin for Firefox
> ... confirming that it's totally non-portable.
> PDF isn't a great format for the web for many reasons including that it always loads the entire 1.5MB document and that "back" buttons are much less reliable when following links in a PDE. Since #page is the most nearly portable solution, I don't mind using that end eventually finding a way to produce good-looking HTML output.
   The only way this will happen is if you write it all your self :-(
> 2) He says you need the hyperref option "destlabel=true".
