[petsc-dev] malloc_dump noise from threadcomm
    Shri
    abhyshr at mcs.anl.gov
    Sat Dec  8 09:49:08 CST 2012
On Dec 8, 2012, at 9:29 AM, Jed Brown wrote:
> threadcomm.c has this thing
>   for (i=0;i<PETSC_KERNELS_MAX;i++) {
>     ierr = PetscNew(struct _p_PetscThreadCommJobCtx,&PetscJobQueue->jobs[i]);CHKERRQ(ierr);
> that gets freed when the last PetscObject gets destroyed. But if the user forgets to Destroy something, this shows up as a memory leak. Since the relevant malloc_dump output is much higher in the stack, this is confusing noise, and I'd like to eliminate it. We can either
> 1. not log this memory at all by calling malloc or posix_memalign directly
> 2. put code into PetscFinalize that ensures that this stuff has been freed (very messy if user does anything weird with communicators)
> 3. add way to mark PetscTrMalloc'd memory as "indirect" so that it is not reported by default
We can go with 1 for now??
Shri
