[petsc-dev] DMSetDefaultSection destroys old sections
Chris Eldred chris.eldred at gmail.com
Thu Aug 30 17:06:09 CDT 2012
The code for DMSetDefaultSection is:
3016:   PetscSectionDestroy(&dm->defaultSection);
3017:   PetscSectionDestroy(&dm->defaultGlobalSection);
3018:   dm->defaultSection = section;
3019:   return(0);
which destroys the "current" default section before setting the new
one. Since my sections are passed by reference in Fortran, the only
recourse I can see is to create a copy of the section before it is
passed to DMSetDefaultSection. Any other ideas?
On Thu, Aug 30, 2012 at 4:03 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> I think the bug is not that the old section is destroyed, but that the new
> one is not referenced.
> On Thu, Aug 30, 2012 at 5:00 PM, Chris Eldred <chris.eldred at gmail.com>
> wrote:
>> I am using DMSetDefaultSection and DMCreateLocalVector to create
>> vectors in my code, but errors are occurring because
>> DMSetDefaultSection destroys old sections. My usage pattern is
>> for each variable
>> call DMSetDefaultSection
>> call DMCreateLocalVector
>> which fails if there is more than one 1 variable that uses the same
>> section since the sections are being destroyed when a new one is set.
>> Is there a reason for this behavior in DMSetDefaultSection (ie can a
>> version of DMSetDefaultSection that does not destroy the old sections
>> be provided)?
>> Chris Eldred
>> DOE Computational Science Graduate Fellow
>> Graduate Student, Atmospheric Science, Colorado State University
>> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
Chris Eldred
