[petsc-dev] Issues with DMComplexGetTransitiveClosure in Fortran
    Matthew Knepley
    knepley at gmail.com
    Thu Aug 30 11:53:24 CDT 2012
On Thu, Aug 30, 2012 at 11:49 AM, Chris Eldred <chris.eldred at gmail.com>wrote:
> That is what I have already been doing- so that is good! As far as the
> ordering convention goes, for a 2D mesh I should have vertices, faces
> (what I have been calling cells) and then edges? Ex. for the doublet
> mesh it would be 0,1,2,3 (vertices); 4,5 (faces); 6,7,8,9,10 (edges)?
No, I do it exactly as in ex2f90:
  cells:      0,1
  vertices: 2,3,4,5
  edges:    6,7,8,9,10
Nomenclature:
  vertex: Complex in mesh of dimension 0
  cell:     Complex in mesh of co-dimension 0 (so highest dimension
possible)
  edge:   Complex of dimension 1
  face:    Complex of co-dimension 1 (notice it can also be an edge in 2D)
     Matt
> On Wed, Aug 29, 2012 at 8:51 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Wed, Aug 29, 2012 at 1:35 PM, Chris Eldred <chris.eldred at gmail.com>
> > wrote:
> >> DMComplexGetTransitiveClosure (and Restore) work fine now. What are
> >> the new restrictions on numbering mentioned in
> >> src/dm/impls/complex/examples/tests/ex2f90.F?
> > In the original Sieve, you could use any id for any point. This is very
> > flexible, but
> > hugely expensive in terms of memory, and somewhat expensive in terms of
> > time.
> > In DMComplex, each stratum in the DAG (it is technically a ranked poset)
> > must
> > be numbered contiguously. This means that vertices, faces, etc. are all
> > numbered
> > contiguously. It turns out that in practice, this is not an onerous
> > requirement, and
> > it allows very effective optimizations.
> > In addition, we have the convention that we number cells, then vertices,
> > then faces,
> > then edges. Nothing in the interface demands it, but all of the PETSc
> code
> > for FEM
> > obeys this since it simplifies debugging.
> >     Matt
> >> On Tue, Aug 28, 2012 at 8:16 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > On Tue, Aug 28, 2012 at 5:01 PM, Chris Eldred <chris.eldred at gmail.com
> >> > wrote:
> >> >> On Tue, Aug 28, 2012 at 3:49 PM, Matthew Knepley <knepley at gmail.com>
> >> >> wrote:
> >> >> > On Tue, Aug 28, 2012 at 4:39 PM, Chris Eldred
> >> >> > wrote:
> >> >> >> DMComplexGetTransitiveClosure does not appear to have the calling
> >> >> >> sequence (DM dm, PetscInt p, PetscBool useCone, PetscInt
> *numPoints,
> >> >> >> PetscInt *points[]) indicated in the documentation- instead it has
> >> >> >> DM
> >> >> >> dm, PetscInt p, PetscBool useCone, PetscInt *points[]. In
> addition,
> >> >> >> it
> >> >> >> does not appear to be returning the full closure- instead it just
> >> >> >> gives cone + the point.
> >> >> > 1) I will turn this code into a running example
> >> >> Awesome! I have been using the Doublet mesh to test DMComplex
> routines
> >> >> and my own functions, so that is great.
> >> > Okay, there was a bug in the array handling. The test is
> >> >   Thanks,
> >> >      Matt
> >> >> > 2) I will fix the documentation. The interface change for Fortran
> >> >> > comes
> >> >> > because the size
> >> >> >     is embedded in the array pointer. If you think I should still
> >> >> > return
> >> >> > the
> >> >> > size in Fortran,
> >> >> >     let me know.
> >> >> I can get the size from the array pointer so just returning that
> works.
> >> >> > 3) I will also check to make sure the documentation is clear that
> >> >> > this
> >> >> > thing
> >> >> > returns each
> >> >> >     point AND its orientation.
> >> >> > Will write again when I have your thing running. It could be an
> error
> >> >> > with
> >> >> > the Fortran array
> >> >> > processing I put in.
> >> >> >   Thanks,
> >> >> >      Matt
> >> >> >> Sample code is below:
> >> >> >> program main
> >> >> >> implicit none
> >> >> >> ! #echo '#include <finclude/petscsys.h>\n'
> >> >> >> #echo '#include <finclude/petsc.h90>'
> >> >> >> #echo '#include <finclude/petscdmcomplex.h>\n'
> >> >> >> #echo '#include <finclude/petscdmcomplex.h90>'
> >> >> >> ! #echo '#include <finclude/petscdm.h>\n'
> >> >> >> ! #echo '#include <finclude/petscdm.h90>\n'
> >> >> >> DM dm
> >> >> >> PetscInt, target, dimension(3) :: EC
> >> >> >> PetscInt, target, dimension(2) :: VE
> >> >> >> PetscInt, pointer :: pEC(:), pVE(:)
> >> >> >> PetscInt, pointer :: nClosure(:)
> >> >> >> PetscInt, pointer :: pClosure(:), pCone(:), pCone2(:)
> >> >> >> PetscErrorCode ierr
> >> >> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexCreate(PETSC_COMM_WORLD, dm, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> !Make Doublet Mesh from Fig 2 of Flexible Representation of
> >> >> >> Computational Meshes (except indexing is from 0 instead of 1)
> >> >> >> call DMComplexSetChart(dm, 0, 11, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 9, 3,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 10, 3,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 4, 2,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 5, 2,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 6, 2,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 7, 2,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSetConeSize(dm, 8, 2,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMSetUp(dm, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> EC(1) = 4
> >> >> >> EC(2) = 5
> >> >> >> EC(3) = 6
> >> >> >> pEC => EC
> >> >> >> call DMComplexSetCone(dm, 9 , pEC, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> EC(1) = 6
> >> >> >> EC(2) = 7
> >> >> >> EC(3) = 8
> >> >> >> pEC => EC
> >> >> >> call DMComplexSetCone(dm, 10 , pEC, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> VE(1) = 0
> >> >> >> VE(2) = 1
> >> >> >> pVE => VE
> >> >> >> call DMComplexSetCone(dm, 4 , pVE, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> VE(1) = 0
> >> >> >> VE(2) = 2
> >> >> >> pVE => VE
> >> >> >> call DMComplexSetCone(dm, 5 , pVE, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> VE(1) = 1
> >> >> >> VE(2) = 2
> >> >> >> pVE => VE
> >> >> >> call DMComplexSetCone(dm, 6 , pVE, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> VE(1) = 2
> >> >> >> VE(2) = 3
> >> >> >> pVE => VE
> >> >> >> call DMComplexSetCone(dm, 7 , pVE, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> VE(1) = 1
> >> >> >> VE(2) = 3
> >> >> >> pVE => VE
> >> >> >> call DMComplexSetCone(dm, 8 , pVE, ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexSymmetrize(dm,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call DMComplexStratify(dm,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> !Test Stuff
> >> >> >> call DMComplexGetTransitiveClosure(dm,10,PETSC_TRUE,nClosure,ierr)
> >> >> >> !pClosure,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> write(*,*) nClosure
> >> >> >> write(*,*) pClosure
> >> >> >> call DMDestroy(dm,ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> call PetscFinalize(ierr)
> >> >> >> CHKERRQ(ierr)
> >> >> >> end
> >> >> >> The output is:
> >> >> >>           10           0           6           0           7
> >> >> >> 0           8
> >> >> >> and then there is an error in DMDestroy
> >> >> >> [0]PETSC ERROR: --------------------- Error Message
> >> >> >> [0]PETSC ERROR: Object is in wrong state!
> >> >> >> [0]PETSC ERROR: Work array still checked out!
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: Petsc Development HG revision:
> >> >> >> b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f  HG Date: Mon Aug 27
> >> >> >> 13:17:10
> >> >> >> 2012 -0500
> >> >> >> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> >> >> >> [0]PETSC ERROR: See docs/faq.html for hints about trouble
> shooting.
> >> >> >> [0]PETSC ERROR: See docs/index.html for manual pages.
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user
> Tue
> >> >> >> Aug 28 15:31:06 2012
> >> >> >> [0]PETSC ERROR: Libraries linked from
> >> >> >> /home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib
> >> >> >> [0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012
> >> >> >> [0]PETSC ERROR: Configure options --download-boost
> --download-chaco
> >> >> >> --download-ctetgen --download-f-blas-lapack --download-fiat
> >> >> >> --download-generator --download-metis --download-ml
> --download-mpich
> >> >> >> --download-parmetis --download-scientificpython
> --download-triangle
> >> >> >> --with-clanguage=cxx --with-dynamic-loading
> --with-shared-libraries
> >> >> >> --with-sieve PETSC_ARCH=arch-linux2-cxx-debug
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: DMDestroy() line 234 in
> >> >> >> /home/user/Desktop/LIBRARIES/petsc-dev/src/dm/interface/dm.c
> >> >> >> application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> >> >> >> [unset]: aborting job:
> >> >> >> Ideas?
> >> >> >> Chris Eldred
> >> >> >> DOE Computational Science Graduate Fellow
> >> >> >> Graduate Student, Atmospheric Science, Colorado State University
> >> >> >> B.S. Applied Computational Physics, Carnegie Mellon University,
> 2009
> >> >> > What most experimenters take for granted before they begin their
> >> >> > experiments
> >> >> > is infinitely more interesting than any results to which their
> >> >> > experiments
> >> >> > lead.
> >> >> > -- Norbert Wiener
> >> >> Chris Eldred
> >> >> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
> >> > experiments
> >> > experiments
> >> > lead.
> >> > -- Norbert Wiener
> >> Chris Eldred
> experiments
> experiments
> > lead.
> > -- Norbert Wiener
> Chris Eldred
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120830/4202e47e/attachment.html>
