[petsc-dev] Error in PetscSectionCreate using Fortran
Chris Eldred chris.eldred at gmail.com
Tue Aug 28 16:49:15 CDT 2012
I am getting a segmentation fault when calling PetscSectionCreate. The error is:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscTrMallocDefault line 183
/home/user/Desktop/LIBRARIES/petsc-dev/src/sys/memory/mtr.c
[0]PETSC ERROR: [0] PetscSectionCreate line 37
/home/user/Desktop/LIBRARIES/petsc-dev/src/vec/vec/impls/seq/vsection.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f  HG Date: Mon Aug 27 13:17:10
2012 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user Tue
Aug 28 15:47:36 2012
[0]PETSC ERROR: Libraries linked from
/home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib
[0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012
[0]PETSC ERROR: Configure options --download-boost --download-chaco
--download-ctetgen --download-f-blas-lapack --download-fiat
--download-generator --download-metis --download-ml --download-mpich
--download-parmetis --download-scientificpython --download-triangle
--with-clanguage=cxx --with-dynamic-loading --with-shared-libraries
--with-sieve PETSC_ARCH=arch-linux2-cxx-debug
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: aborting job:
The relevant code section is:
call PetscSectionCreate(PETSC_COMM_WORLD, section, ierr)
CHKERRQ(ierr)
call PetscSectionSetChart(section, 0, 11, ierr)
CHKERRQ(ierr)
do p=0,10
 call PetscSectionSetDof(section, p, 3, ierr)
 CHKERRQ(ierr)
end do
call PetscSectionSetUp(section, ierr)
CHKERRQ(ierr)
call PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD, ierr)
CHKERRQ(ierr)
call PetscSectionDestroy(section, ierr)
CHKERRQ(ierr)
Ideas?
Chris Eldred
DOE Computational Science Graduate Fellow
Graduate Student, Atmospheric Science, Colorado State University
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
