[petsc-dev] Patch review
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Aug 28 10:23:00 CDT 2012
I just pushed some fixes for compilation in complex mode
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/49030d6e26f7
In the following code, surely you intended to pass inner_rtol to
KSPSetTolerances()?
PetscErrorCode KSPMonitorDynamicTolerance(KSP ksp,PetscInt its,PetscReal
fnorm,void *dummy) {
  PetscErrorCode ierr;
  PetscReal *coef = (PetscReal*)dummy;
  PC pcksp;
  KSP kspinner;
  PetscReal outer_rtol, outer_abstol, outer_dtol, inner_rtol;
  PetscInt outer_maxits;
  PetscFunctionBegin;
  ierr = KSPGetPC(ksp,&pcksp);CHKERRQ(ierr);
  kspinner = NULL;
  ierr = PCKSPGetKSP(pcksp,&kspinner);CHKERRQ(ierr);
  if (kspinner) {
    ierr = KSPGetTolerances(ksp, &outer_rtol, &outer_abstol, &outer_dtol,
&outer_maxits);CHKERRQ(ierr);
    inner_rtol = (*coef) * outer_rtol / fnorm;
    ierr = KSPSetTolerances(kspinner, outer_rtol, outer_abstol, outer_dtol,
  PetscFunctionReturn(0);
On Fri, Aug 24, 2012 at 6:44 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Aug 24, 2012 at 6:38 PM, Jie Chen <jiechen at mcs.anl.gov> wrote:
>> I am in fact somewhat reluctant to push out everything before it is
>> formally published and fully tested. The patch consists of more than one
>> algorithmic developments that may be far away from maturity (but they are
>> likely to work), though the authors might be the only ones who care about
>> the new algorithms at this point. Besides, the codes are now full of hacks
>> and lack documentation. I have no problem reverting petsc to the old
>> version temporarily, and I promise I will clean everything to meet the
>> production requirement, although this might not happen in a very short
>> time. Meanwhile I think it also does not hurt to keep the patch as is, as
>> the modification is likely to be used by the author circle only.
> There isn't a problem with experimental code, but if you are going to push
> experimental code, it should conform to the usual standards. No need to
> revert the patch unless you've already decided it is a failed experiment.
> If something is genuinely useful, we certainly like to have it in our bag
> of tricks immediately. Waiting until a paper is published to put it in the
> repo just means that it will take longer to find use in real applications.
> As far as I'm concerned, an ideal scenario is that by the time someone
> reads the paper, they already have the functionality in a released version
> of PETSc, thus can experiment on their own problems without even
> recompiling. (This being the lowest possible effort, it maximizes the
> chances of finding other applications where the method is useful, thus
> maximizing citations, in case that is the metric you care about.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120828/4faa7b87/attachment.html>
