[petsc-dev] [PATCH 3 of 3] cmake: replace invalid characters with underscores
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 27 21:50:12 CDT 2012
Satish might.
But if you send me the patch I'll try it and get it working (at least I'll get the python end working; if you get me some thing that is basically right I can get it working). Basically its a few lines of python that handle the -framework xxx stuff
Thanks
Barry
On Aug 27, 2012, at 9:46 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Aug 27, 2012 at 9:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> But you don't need to screw with the -I since the compiler always looks inside the frameworks for the include based on #import <OpenGL/gl.h> etc. That's right the -framework flag is actually ignored at compile time and only needed to link the program so Apple is bogus big time man.
> and why bother with -L etc etc. Just list the damn library by its full path and pass that to cmake?
> Perfect, that's what CMake wants.
> Does someone have a VM I can log into to test?
