[petsc-dev] [PATCH 3 of 3] cmake: replace invalid characters	with underscores
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Aug 27 21:44:45 CDT 2012
On Aug 27, 2012, at 9:36 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Aug 27, 2012 at 9:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  All you need do is search through the framework directories (Sean kindly provided the list) for xxxx.framework then the dynamic library is in that directory called xxxx (yup no suffix!).  Now you have a complete path to pass to cmake. I am kind of surprised that someone hasn't provided a cmake utility to do this already (since it must be very common), perhaps
>    Google finds some odds and ends like this http://twogregui.googlecode.com/svn/trunk/TwOgre/cmake/OgreFindFrameworks.cmake  but like everything associated with cmake it is incomprehensible.  Side question: why do all configure systems have to be so fucking incomprehensible?
> I know, it's such a disaster.
> I don't know whether it's better to write that damn custom CMake logic in CMake or to just do it in Python, converting to -I/-L/-l/-Wl,-rpath options.
   Do it in python.
    But you don't need to screw with the -I since the compiler always looks inside the frameworks for the include based on #import <OpenGL/gl.h> etc.  That's right the -framework flag is actually ignored at compile time and only needed to link the program so Apple is bogus big time man.
    and why bother with -L etc etc. Just list the damn library by its full path and pass that to cmake?
    Barry
